ai Exterior Facade Explorations on EvolveLAB Revit Hotel Model With Veras
Writer: Ben GulerBen Guler
Revit View Setup
Follow step #1 in this post for the view setup: Rendering Exteriors in Revit
1 | Faceted Facade
All the renderings below have the same settings including the prompt:
Creativity Strength: 100 Style Strength: 38 Width: 768 Is Interior: OFF Turbo Nature: ON Atmospheric: ON Aerial: ON Prompt: articulated facade, rectilinear, high contrast, surfaces with sharp edges and sharp corners, reflective and matte mosaic surfaces, glass and steel, designed by daniel libeskind, white sky, faceted facade, golden hour, white walls
2 | Voronoi Facade
All the renderings below have the same settings except for the prompt. See prompt below each render.
Creativity Strength: 95 Style Strength: 34 Width: 768 All toggle settings are OFF
Prompt: articulated faceted facade with voronoi fractalization design, designed by olafur eliason, creek, lush
Prompt: articulated faceted facade with voronoi fractalization design, rectilinear, sharp edges and sharp corners, designed by olafur eliason, in a busy city at night, with traffic
Prompt: articulated faceted facade with voronoi fractalization design, rectilinear, sharp edges and sharp corners, designed by olafur eliason, in a busy city at night, with night traffic
Prompt: same as above
3 | Surface Mix Facade
Creativity Strength: 82 Style Strength: 48 Width: 768 Turbo Nature: ON Aerial: ON All other toggle settings are OFF
Prompt: articulated facade, rectilinear, high contrast, surfaces with sharp edges and sharp corners, concrete matte mosaic surfaces, concrete and steel, designed by daniel libeskind, white sky, faceted facade
