Rendering Interiors In Revit With AI
Writer: Ben GulerBen Guler
  • Open the rac_basic_sample_project that comes with your Revit installation
  • Go to a 3d perspective view that is uncropped
  • Set the view to Realistic mode
  • Go to the Graphic Display Options… and update the settings to match the screenshot
2 | Render the View
  • Find an interesting position for the Revit view
  • Start the Veras app under the EvolveLAB Ribbon tab
  • Right click on the gray canvas, and select Show Revit Preview. This will show you the framing of the view before it will be rendered.
  • Click the Render button at the bottom of the property pane if you’re happy with the rough composition
  • If you get a network error, please see this troubleshoot post 2
Tip: it helps to make the aspect ration of your view similar to the render resolutions selected. Ex: if square, the Revit window can be adjusted into a square ratio 3 | Living Room All the images below share the common settings below. The only change is minor prompt adjustments in bold. Creativity Strength: 100 Style Strength: 50 Width: 1536 All Optional Toggles are off
Prompt: living room, white walls, white ceiling, gray wood floor, forest outside seen through the larger glass windows
Prompt: living room, white walls, white ceiling, gray wood floor, forest in autumn outside seen through the larger glass windows
Prompt: living room, white walls, white ceiling, gray wood floor, forest in autumn outside seen through the larger glass windows 4 | Dining Room All the images below share the common settings below. The only change is minor prompt adjustments in bold. Creativity Strength: 100 Style Strength: 50 Width: 1536 All Optional Toggles are off NOTE: these renderings can be further defined with additional key words, ex: white chairs, wooden chairs, etc…
Prompt: modern kitchen, white walls, white ceiling, gray wood floor, forest outside seen through the larger glass windows
Prompt: modern kitchen, white walls, white ceiling, white concrete floor, forest outside seen through the larger glass windows
Prompt: modern kitchen, white walls, white ceiling, white concrete floor, forest outside seen through the larger glass windows Tip: if you have images that are pixelated or blurry, the Style Strength might be too high. Try lowering it to 30 or below. This happens with higher Creativity Strength values To try Veras, you can visit www.evolvelab.io/veras
